MAP sensor not used on factory ecm?
HYBRIDT
I just purchased Direct-Scan and was reading through the instructions and it said "the ECM does not actually have a manifold pressure input", but it uses "a calculated 'guess'by the ECM" to sense boost????? I thought the MAP sensor was there to tell the ECM vacuum AND boost conditions. What's the deal.
Adam
P.s. if this is in the wrong section please move mod. Thanks.
the only thing the map on a buick does is light the stock boost gauge
digital dash cars dont even have a map sensor but a pressure swith to light the boost lights in the dash thats what the other plug in the harness by the map sensor is for
