map sensor problems...
cecil bass
Hello i need some help with installing a map sensor on my 1987 we4 turbo T, with digital dash. I think my car didn't come
With a map sensor but i have a hops switch how do i install the map sensor along side the hops switch? Can i just run a tee to the vacuum line and feed both of them? And do i even have the electrical Connector on a digital TR harness? If so where would i find such a connector? Thanks on any info you can provide!
Why are you installing a MAP sensor?? Yes the plug is there. The Hobbs switch activates the turbo lights on the dash...which are useless.
Bryan
The Alky directions tell you how to connect it. You will need a 5v source. Julio sells an adapter so you dont have to splice a wire.
Bryan
