SignUp Now!the cool string of blinky lights in the dash by the tach won't work any more..So I could just rip the the map sensor out and it wouldn't affect anything?
its very difficult to get accurate fuel air mixtures with a MAP sensor system it also limits total amount of Cam and Mods, the MAF system on the other had is much much more accurate - especially in a turbo car and can modified in more ways.
A.j.
A.j,
I agree to some extend.![]()
All the aftermarket and piggyback systems, including the TurboTweak SD chip are Speed Density and run off the MAP, MAT and WB.
So your statement is correct; With "just a MAP", it is difficult.
Add the other two sensors, and it just got a whole lot easier. :biggrin:
Also .........
If you never intent on running Progressive Alky injection, or PL, and don't care about logging data and/or the very notoriously inaccurate stock in-dash X-mas boost lights ............. than remove the MAP. :biggrin:
most other factory efi systems use both a MAP and a MAF together.its very difficult to get accurate fuel air mixtures with a MAP sensor system it also limits total amount of Cam and Mods, the MAF system on the other had is much much more accurate - especially in a turbo car and can modified in more ways.
A.j.
MY next question is where do you hook up a vacuum/boost gauge to?
