MAP wiring for the Razor kit
5 LTR KLR
OK I am newbee and I was wondering if I could get some help on this please...
I know the following: ON MAP sensor wire hareness- C is the grey wire, B is the green wire, & A is the black wire.
HERE IS MY QUESTIONS....
### NOW on the pins on the ECM harness- such as the D12 pin do I run a wire from this wire to the "grey" wire in the MAP wire harness (which is the C wire)???
### THEN from pin C14 do I run another wire from this wire to the "black" wire in the MAP wire harness (which is the A wire)???
### LASTLY then I run a wire from the "green" wire in the MAP harness to the green wire from the PAC device???
ANY HELP OR POINTS WOULD BE GREAT!!!
THANKS GUYS!!! :cool:
Yes.
Now the black wire is a ground. Some will use the ecm ground wires, some will just attach it to a chassis ground.. like a metal bracket(any) behind the dash. Whatever you do.. it should read ZERO volts once connected.
The only important part is that the gray wire on MAP plug gets 5 volts. This is D12 reference. Key "ON".. reads 5 volts. And it is also gray in color. So attach a wire to the D12 gray wire.. and attach it to the gray wire going to terminal C on your 3 bar.
Green wire on MAP, attach supplied green wire and run it to the PAC green.
