SignUp Now!Originally posted by 6SENSE
My MAT sensor has been in the stock 86-87 location, between the air filter and MAF sensor (actually in the neck of the K&N cone filter). What Im proposing is a actual (more accurate) reading of the intake temperature. lowering intake temps (and subquently cylinder temps) is what the addition of an intercooler is meant to accomplish. Lowering the intake temp is what many of us have added alky injection for, thus it would be nice to know what I am actually accomplishing. This isnt anything new, there are 86-87 guys that have already done this. I was just wondering if anyone with a hotair have done it, or have any ideas about it (i.e. where would be a good spot on our intakes to relocate to).
I guess MAT stands for Mas Air Temperature not Manifold Air Temperature, huh? Because if it were Manifold Air Temp, youd think that it would get more accurate #s if istalled in the intake maifold.The MAT is used in the fueling calculation. And the timing vs MAT is 0'd out.
Got the ECM, translator was a possible future mod, and chip burning has always been a dream of mineIf you go to the 87 ecm and then the Translator, and edit your own chips you can do good things.
Originally posted by TType84
the stock mat sensor is really slow to react.. i hooked it to a dvm and put it infront of my ac vents in my house and the voltage change was very very sllow, it did this on tlink too.
basically, if you put it in the intake, unless you stay in boost for awhile, youre never gonna see the actual intake air temperature cause the sensor takes so long to heat up..
Ahhh, okay. Thanks bruce.
Since Ive usually got the MAT unhooked anyway for TLink's boost sensing hardware, couldnt it be used (installed in the intake) to get readings for a gauge?
Got the ECM, translator was a possible future mod, and chip burning has always been a dream of mine![]()
6SENSE said:Anyone try this? Any known ideal spot for placement? Would be the ideal tool (other than EGT) for us "intercooler-challenged" guys (especially when trying to compensate and tune with alky/H2O).
Nope never got around to making it happen.Jerryl said:I am still behind the 8-Ball.![]()
Reason I am looking at this is becasue my chip writer says that the IAT is used. (It will actually be a MAT)
6SENSE,
Did you ever place this in the intake?
Did you ever record before and after "Alky temps"?
Jerryl said:Decided that this is a BAD idea for a Hot Air.
The IAT (in this case MAT) element is soldered and solder melts around 450F
The Hot Air intake air charge can possibly get into the 300-400F range.
Probably already figured that out.![]()
bruce said:Have you unsoldered one?, or are you just looking at it's apprearance?.
http://www.geocities.com/jeffhendrix67/lv2000/solder.html
Solder flows at a fairly low temperature, around 360-370 degrees Fahrenheit.
First off, I am no expert and KNOW that methanol works.cool 84 said:My dad ran the westech guages when it was a hotair in the plug in the front of the intake manifold. At 20psi it was around 340 degrees. After the 87 conversion, it went to 120 degrees with big turbo and intercooler. With the alky triggered it pegged the guage as low as it would go at 60 degrees on a 70 degree day. I'm very interested to see how cold it gets with alky on a hotair. It should have a bigger effect without the intercooler.
Agree 100%, no pun intended. :smile:6SENSE said:........I feel like the margin for error in that regard is a bit less with 100% h2o but if things are just right there is a definate benefit to the cooling effect that it has. I might start playing around with a 50/50 mix again, but just a bit weary about the h2o with the BIG m15 nozzle fed by the mighty surflo if I dont know that its definately being atomized.
