turbo39151
anycoloraslongasitsblack
- Nov 7, 2002
I was just curious about matching numbers...
When you match the numbers are you looking at the : vin, engine block, trans, and frame? (or is there more)?
Are these numbers supposed to be the last few numbers of the vin or how does it work?
I ask because I was under a tr yesterday and wiped the LH side of the trans housing (it was all grimy and I was doing a trans mount). Anyway, I wiped the grime and on the side of the bellhousing it said Hydromatic and below that there was a number several digits long (can't remember how ong exactly). I read off the VIN and none of the numbers seemed to jive. Maybe I'm reading it wrong?
Can someone post pics of the locations as well?
