Mike T
- May 3, 2013
How are guys capturing the actual 'graph' screen in your posts???
I use print screen and send it to paint, looks like Dave has a better method.
SignUp Now!How are guys capturing the actual 'graph' screen in your posts???
I was able to save a log today. I'm beginning to think the knock I encountered at 20# was due to the TC locking up and rpms getting pulled down. Anyway, here it is:
Yes this was after lowering the boost. I basically just measured the old stock wastegate and set the adjustable one to that length. I also backed the Boostvalve controller out until only a few threads were holding it. I noticed the TPS too. I had it to the floor. The TPS still reads from .44 to 4.3v solid when I checked it after I saw the log. I'll keep an eye on that next time as it looked like it was all over the place and never got over 4v.0 knock in this log. Was this after lowering the boost ? Looks like you were not at WOT per the TPS.
Mine is set at 4.75 but to be honest I found no power difference between 3.75 and 4.75 WOT on the Powerlogger when logs were compared, may be other advantages that I missed.I understand you need a WOT reading of 4.75 or greater? AC cut off or the like? I'm not certain on the .75, maybe higher? I read somewhere.
Joel
I read anything over 3.75-4v is considered WOT? I was going to replace my TPS sensor when I found out it was 'maxed' at 4.3v, but read that 4.3 was sufficient. I checked the TPS again(key on without engine running) after I saw the low voltage on the log and it still went to 4.3v. That's why I don't get the strange readings on the pl file.Mine is set at 4.75 but to be honest I found no power difference between 3.75 and 4.75 WOT on the Powerlogger when logs were compared, may be other advantages that I missed.
Ive been to 20psi plus on 93......everyday boost level is 16.4 ..... Made 300 horse at the wheels at the tb.com nats at richards a couple weeksago at 16.4.......
Te44
3.5 down pipe
Stretched sfock location ic
60lb inj
Tt chip
Ported stock heads and intake
Stock cam
Oriellys bought short bock, lol
I went 11.90@118 on 93 and only 18#. No alky
