When you over tighten,it becomes more sensitive.Make sure you have the right torque spec on the sensor. If you over tighten it may not work properly
X3Im with bison around 17 psi and decent timing is all with 93. Of course thats give or take on many variables to each engine give or take a few psi.
About 17-18psi on a calibrated MAP sensor and
timing retarded considerably more than would be used with higher octane. Some might see 19psi and some might see 16psi. A good map sensor doesn't leave any question as to what's actually happening. Gauges are all over the place
TurboDave said:True enough. Which is why I run both, an aircraft quality, and calibrated gauge, and a recently calibrated 3 bar map.
I'm convinced the stars and planets are all aligned for my setup.
What do you have for heads if you don't mind me asking? That's impressive! I am not sure I would attempt to go there without the methanol safety net.True enough. Which is why I run both, an aircraft quality, and calibrated gauge, and a recently calibrated 3 bar map.
Dave if you don't mind what injectors are you running and what is the duty cycle when running that kind of boost?True enough. Which is why I run both, an aircraft quality, and calibrated gauge, and a recently calibrated 3 bar map.
My motor is bone stock, except for external add-on's. Turbo, inj, FMIC.What do you have for heads if you don't mind me asking? That's impressive! I am not sure I would attempt to go there without the methanol safety net.
