S
Sergeant
Guest
Was reading about this in GM high tech performance. My question is with the stock brake system with the exception of larger and softer brake shoes how much boost can you launch on as aposed to the Launch Kit? Would you really want to launch at a much higher boost if it is just going to lead to wheel spin. Using stock rear suspension except for atr bar, poly bushings on the control arms and drag radial slicks.
