Max Effort 8 Pos. for 50#/Translator
noslo6
87 Grand National
I've got a Max Effort 8 Position programmed for 50 lb. injectors and also programmed for use with a Translator. I sent the chip to Steve about 6 months ago to get it reprogrammed to work with a Translator. It works great, I've just changed my setup and don't need it any more. $150 OBO or trade for new cam/lifters.
I'm sure it should work with the T+ as well. The code is modified to accept the MAF signal. I was running a TE-60, but Steve said it was set up HOT which I took to mean plenty of fuel. At 25# or more of boost, I never had to fuel it past 5 running 40# of fuel pressure, so it had plenty of room left. If you ever have any modifications to be made, Steve is super cool and helpful and will make any changes you want cheap if necessary. Translator switches in the middle except idle...2, lean.
