david buschur
- Mar 14, 2004
I've searched these forums from one end to the other. Cannot find the answer I am looking for so I have to ask one.
I've owned an '87 WE4 for about 7-8 years. Beautiful car, 34,000 miles. I've had nothing but problems with trying to make it go fast. One after another and have never fully tracked it down, until recently.
I've always run race gas in the car. Well not sure what kind of crap I got into but a mixture of water and some type of seriously thick goo finally did the entire fuel system in to the point of no return. Return line was completely plugged shut, couldn't even force 100 psi air through it.
Long story short, I have decided to turn the car into a full TSM car. I don't drive it enough to care.
Doing a 109 engine build. Steel crank, forged rods, lightweight forged pistons, front, rear and center mains, girdle, balanced etc. This is the second one of these I built this way, the first I sold as I lost interest in the car with the problems I couldn't find. We actually machine the tops of the mains perfectly flat to the oil pan rail and then bolt the girdle on, it's bad ass to say the least.
Finally, here is the question. What is the maximum RPM you guys are running on an the fast 109 blocks? One just went 8.90's, it has to take some RPM to run that fast. The stock block in my car now has been to 6100 rpm numerous times. Is 7,000 rpm possible?
Thanks for any input. I'm an RPM freak, guess I'm use to building 10,000+ rpm 4 cylinders making 1,000 HP![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
David Buschur
David Buschur
