SignUp Now!Just got my powerlogger hooked up and noticed that im maxing out the maf sensor already.
All my mods are in my sig, im running right at 22psi throughout. How can i scale it down, or fix the issue with the TT chip?
TIA
Cody
There is nothing to fix. That's exactly what it should be doing.
You can't adjust the fuel in 3rd independently. In the chip, the fueling in 3rd is the same as 2nd gear. You're probably seeing the O2 sensor heating up which shifts the numbers down. My car might start in the 820's and end up at 750's by 3rd gear, but the A/F ratio is exactly the same on the wideband (11.5 through the whole run).
For timing, I wouldn't exceed about 23* for daily driving. For the track, many alky users have run 26-27* (or higher for the stock turbo). No comment on whether it's "safe" or not.:biggrin:
