ME, 16 pos., EXT???
turbo buicks
ESADAH!!!
is a 16 position thumbwheel chip like the ones caspers sells the same as an extender or maxeffort chip?
No, it's not like either.
The Extender is NOT a thumb wheel chip. It's a standard type chip for use with a Translator setup. It works pretty sweet though as you can adjust several things including fuel and timing(with the Translator + unit). I use and reccomend this setup. Here is a link to more info:
http://www.ramchargers.com/RamNews/Translator/extender_manual.htm
Here is a link to the Translator + info:
http://www.ramchargers.com/RamNews/Translator/translatorplus_manual.htm
The Max Effort is a thumbwheel chip available in 8 and 16 position types that is an open loop based chip that enables you to set/adjust several operating parameters yourself. Lots of guys going fast with this setup as well. Here is a link to more info:
http://members.tripod.com/turboracer/maxeffort/
Hope this helps..
thanks U1ARUNIT, so are the ME and Caspers Thumbwheel chips the same? the ME says mechanical boost control is needed. will this work w/a BstC?
The ME and Caspers chips are not the same and the ME will work with a boost comander.
Steve
