ME-16pos, Accelerator pump/TB size????
KEVINS
Does this feature only fix part throttle cruising hesitation or can I tune it to launch the car when the light turns green? If I feel the car is a bit sluggish when I mash the throttle after buildiing boost on the line, will changing the accelerator pump parameters help cure the sluggishness?
Just not sure when/why to adjust this feature.
KS
Hee Hee.. Naaa.
I read that the accelerator pump on the ME acts like one on a carburator and we use to tune the carbs to give a decent shot of fuel to help flash the converter on the starting line. So I thought maybe it would help do the same thing. But it won't. It's the 0-4000 that I need to play with;)
ks
