Alright here's the scoop. I am replacing all of my suspension this year. I did the rear and am done and happy with that.
I tore into the front end, I have the drivers side completely tore down... the coil spring is out, strut is out, sway bar disconnected, spindle off, pretty much everything except for the upper and lower control arms.
The passenger front is nearly the same with the exception of the sway bar bolt which will not come off.
Here is what I want done because I just dont feel like doing it anymore and I am worried I might mess something up:
1. I need the upper and lower ball joints replaced in the front on both sides.
2. I want the upper and lower control arms removed and the new bushings put on... which I was told you can only start, and then have to put the car back together, put weight on the front end, and then finish to tighten so your car doesnt sit all jacked up in the air.
3. I then want the coil spring put back in and the spindles back on so they are in place...
Once that stuff is done, I could probably take care of the rest no problem.
I just dont have the patience or the experience or the tools to do this myself.
PROBLEM:
You would have to come to my house in lockport and finish it in my garage as the car is up on jack stands and all torn apart.
If anyone is interested please contact me, I will pay you cash. You tell me what you want for the job before hand.
I would really like someone who has done this job before to do it... not somebody who's just good with a wrench.
PROBLEM:
