first off let me say that my research into this DIY EFI is still in its beginning stages, but for what i want it seems about perfect, its is a no frills system built by 2 electrical engineers that were upset with the current prices for fuel injection systems, and designed a system and software to support it and since then others have come up with more programming, before you look at the DIY look at the site, i was sceptical at first, still am, but it is not for someone that wants a bolt on half day project, but those that have the know how, want for an inexpensive system( about 250 for an fully programable ecu, its own version of a scanmaster, real time computer simulated gauge display, short preiod data logging and so on) its just about perfect for me. i do not need all the bs that comes with the systems that cost a few thousand, they are comming up with a distrubuterless system based off the ford system ( and before you knock the ford part of it, read the info, it is truly an amazingly easy system to put on a custom setup) i am going to use a non lockup trans, seperate boost controller, switch for fans and so on, so its what i want, but for nothing more than some reading and the posibility of seeing how an ecu works check out the infromation on the site, i think you will be interested.
Grant
http://www.megasquirt.info/
Grant
