Method for measuring front unit end play on 2004R
PaulRV6
What method do you use for measiuring this without the special tool? Is the shaft threaded inside to pull up on? How do you grab the shaft to pull it up and then where do you position the dial indicator? This is with the assembly still inside the case. Thanks
PAUL
It is detailed in the ck book. I sent you a pm on how I did mine.
Here?
I'll have to look through my pix again and see. I'm sure I measured as I changed all three selectives for thicker pieces and put a thicker .080 bushing in on the rear of the sun shell .
