Ross Riker
- Aug 4, 2004
This is a solid roof 87 GN that is 100% street able. Everything is in working order A/C PS, PW, PDL, power seats etc… The car has just over 100k but the motor is fresh with less than 1000 miles on it. Many of the parts as in the turbo 70 GTQ, Rossler TH400, Neil Chance converter, tires and many other parts have less than 400 miles on them. I bought the car off of turbo Buick almost a year ago. When I bought the car it had ran a best of 10.40 @ 131 and made 604hp 644tq to the wheels with the slips to prove. It ran these time with a P-trim 70, bone stock intake, and a 200R4. I have changed many other parts on this car from H&R mounts to a Rossler Tranny to make it more reliable and faster. This car has the potential to run 10.0 to 9.9 and if you want to push the car it would do better than that. It also has a roll cage and this is the best riding car I have been in with a roll cage. It doesn’t squeak and rides great. Almost everything on the car from the motor, tranny, rear end, interior, tires etc is brand new. I would not selling this car if it wasn’t for building of my house. I know theres is a lot of information I’m leaven out so if you have any question PM me and I will give you my #. 18,000 FIRM
Girdled 109
JE pistons
Stock Rods
Stock Crank STD/STD
210/214 Complete Roller Setup
1.65 T&D’s
Champion 14 blot aluminum heads Ported & Polished
Champion intake to match heads
Champion 2 inch spacer
Precision 70mm upper plenum
KB 70mm Throttle body
84 lbs injectors
Dual intake walbro 340’s
FAST Bank-to-Bank
Stock headers welded & ported to match heads (jet coated)
3 ½ inch Terry Huston down pipe (jet coated)
3 ½ exhaust with a 12 inch Bruns Stainless light weight muffler
70 GTQ w/.85 Precision exhaust housing (jet coated)
High Volume actuator
Precision front mount
Precision remote oiling system
F-Body radiator w/ dual fans
All RJC pulleys
Rossler TH400 w/ H&R tranny mount
The rear end is completely built
Auburn posi
Richmond Gear
Moser axles w/ open end studs
TA rear end Girdled
Welded axles tubes
Support braces welded from pumpkin housing to axles tubes so rear wont twist
Brand New MT Drag Radials
Brand New front tires
Just had the seats reupholster, new carpet, headliner, & visors
All brand new auto meter gauges oil pressure, water temp, boost, volts, A/F & DPSS tach
Brand New gas tank
I know theres more I just can’t remember everything. If you have any question just ask or PM me and I’ll give you my phone # to talk in person.
Ross
http://i112.photobucket.com/albums/n171/doubler87/Picture005-1.jpg
http://i112.photobucket.com/albums/n171/doubler87/Picture006.jpg
http://i112.photobucket.com/albums/n171/doubler87/Picture014.jpg
http://i112.photobucket.com/albums/n171/doubler87/Picture007.jpg
http://i112.photobucket.com/albums/n171/doubler87/Picture009.jpg
http://i112.photobucket.com/albums/n171/doubler87/Picture010.jpg
http://i112.photobucket.com/albums/n171/doubler87/Picture011.jpg
http://i112.photobucket.com/albums/n171/doubler87/Picture008.jpg
http://i112.photobucket.com/albums/n171/doubler87/Picture015.jpg
http://i112.photobucket.com/albums/n171/doubler87/Picture016.jpg
http://i112.photobucket.com/albums/n171/doubler87/Picture018.jpg
Girdled 109
JE pistons
Stock Rods
Stock Crank STD/STD
1.65 T&D’s
84 lbs injectors
FAST Bank-to-Bank
All RJC pulleys
Auburn posi
Richmond Gear
TA rear end Girdled
Welded axles tubes
Brand New gas tank
Ross
