Mike from Full Throttle?....
If you want to use the TT chip. I would go with the MaF translator Gen 2. If you are going to use the Maf Trans Pro. Then you don't need the LS1 Maf since you can run speed density. If you are using the Maf trans GEN 2 or the Maf Trans Pro, you are probably better off using the Extender chips since they are designed with features that make the Maf trans work better.
David
87gn
