Mild miss or studder after 112 fuel
fleebag
So I decided to try some racing fuel and bught 112 leaded.
I put in 5 gallons and had about 8 or so already in the tank.
I am getting a weird miss/studder now but not certain if from fuel. It was running rich per PL/SM so I reset the chip and my fuel pressure was at 50psi. so I backed down to 44psi. AFR is somewhat normal at cruise but I can feel it missing. Also, hear a small clicking by the injectors louder than before.
Can the leaded fuel do this? Maybe messed up the o2?
thanks in advance
You probably fouled the plugs and maybe the 02 sensor. I did the same thing on 110. It didn't even want to do a burnout but ran great after building boost.
yea i pulled #1 plug but it was ok. going to do a wot run with p-logger and see
thanks
I run Sunoco purple all the time and have not had a problem. You only checked one plug, one of the others may be fouled by lead. Bruce
yea i put in new o2 and #3&4 plugs were wet. replaced plugs and drained some gas out and so far so good. think the cruising around town instead of wot made me foul the. thanks
