mini starter
Get one at your local parts store. A starter for a 93-97 LT1 f body will work just fine. I seem to remember 323-488 as the reman Delco number. Mine even came with the correct bolts. If not, you will need new bolts. The LT1 unit is a gear reduction type that has to be less than half the weight of the oem unit. Thanks, Counterman.
Is it a direct fit-no shimming??
correct... may or may not need new bolts... as long as the stockers don't bottom out in the block, you're ok.....
