2 BAR MAP Sensor (Works perfect went w/ alky system)
Stock MAF Sensor (Works perfect)
Brand new never used coolant overflow container w/ rubber hose
Old/used coolant overflow
VDO Boost Gauge and all required parts needed for install (used)
Automemter Phantom Fuel pressure Gauge (used)
Braided steel line for Fuel pressure Gauge long enough to mount on hood
Stock turbo shield (cut to fit Terry houston Pipe Painted heat resistant black)
Stock fuel pump (used)
Computer chip for 50lb injectors 22 degree timing
Reds 93 chip
Stock oil fill tube (used)
stock fuel pressure regulator (used)
musclgn@comcast.net
Reds 93 chip
musclgn@comcast.net
