87 WE2
- Jun 28, 2002
Fuel pressure monitoring for powerlogger:
Includes 100psi autometer sending unit #2246, & wire harness #5227, Russel guage adapter for 1/8" NPT fuel pressure take off needed for sending unit, mounts to end of fuel rail.
3 wire installation, gray wire to tps. 5v reference, ground, purple wire to I/O block for monitoring.
Paid over $150 for everything 3 months ago, $130
Kenne-bell fuel pressure guage 1/8" NPT take off for supply line of fuel rail $30
Pats 12" 2800 Stall LU heavy duty converter, removed from my GN aprox 2000miles on converter $175 + shipping
Autometer guages from my GNX style dash, changing it up a bit.
Gauges will come with all hardware, light sockets, bulbs, bulb covers, Speedo cable, adapter, new nylon line and fittings for the boost gauge, new sending units for oil press, water temp gauges.
Gauges are in excellent condition been in the car for about 3 years, 2000 miles if that.
You can pick up a dash plate to mount these in at Turbo Buick Mods . Com
3 3/8
Pro comp 10k tach
Pro comp 120mph mech speedo (can be sent to auto meter for odometer change $20)
2 1/16
Sport comp (short sweep) Oil Press (elect)
Sport comp (short sweep) Water Temp (elect)
Sport comp (short sweep) Fuel Level (elect)
Sport comp (short sweep) Volt (elect)
Sport comp (full sweep) 30/0/30 Boost (Mech)
$400 for all.
Lower rear control arms (stock) need new bushings $50 pair
Stock rear swaybar $25, with hardware $30
Steel break drums $20 pair
Stock lisence plate bracket/fuel door $10
1 rear black GN bumper $50 pick-up only
1 rear steel bumper support $10 pick-up only
1 front steel bumper support $10 pick-up only
USED EGR VALVE (NOT AC DELCO) $10
EGR SILONIODE (KNOW GOOD, LOW MILES) $45
STOCK THERMOSTAT HOUSEING $5
STOCK OIL COOLER ADAPTER NUT $10
INTERCOOLER TO TURBO COUPLINK (HEAVY DUTY, LOW MILES) $5
NEW stock THERMOSTAT $3
HOOKER TESTPIPE 16 ¼” in length $15
COILPACK (KNOWN GOOD) $50
VACUME BRAKE BOOSTER WITH NEW VACUME BRAKE MASTER CYLINDER $45
2 ½” exhaust clamp $1
Passenger side valve cover stock spark plug wire holder $1
Blower motor relay bolts to heater box under hood still shiny $15
Exhaust donut for exhaust elbow to downpipe low miles great condition $5
Used cam sensor 53k known good. $50
Chrome stock valve cover oil fill tube, with cap. $55
Stock exhaust elbow, flow matched for exhaust wheel on bigger turbo. Was on a new TA-60 purcahsed from John Craig. Used for a couple weeks till I upgraded to a 3" downpipe. $50
STOCK TRANS PAN BOLTS 200R4 $10
8.LSFITURBO (MISSING THE 3) $free+ shiping
2 used GN fender emblems $20 each
2 used intercooled emblems $10 each
Dew wipes for driver & passenger side door interior window glass, used in great shape $50 (these attatch to the upper door panels, can get pics)
USED ORIGINAL CRUISE CONTROL/TURN SIGNAL STALK KNOWN GOOD $45
STEERING WHEEL COLLER BOLTS BEHIND STEERING WHEEL FOR DRIVER $free+ shiping
ACCLERATOR PEDAL $free+ shiping
HEATER/AC CONTROLER (KNOWN GOOD, LOW MILEAGE) $25
Upper door panel pull strap trim piece $20
PAIR OF QUARTER PANEL VENTS $10
TRUNK LATCH & LIGHT WITH HARDWARE $10
(2) BUMPER MARKER LIGHTS $25 pair
Pictures available upon request.
3 3/8
Pro comp 10k tach
2 1/16
$400 for all.
