1. Is the timing chain tensioner required? do you prefer to run the motor with it or without it?
2. When installing a new torque convertor do you fill it with any tranny fluind at all or install it dry and let the pump push fluid in?
3. In your opinions what is the best cam break in procedure. Is there a procedure listed on GNTTYPE.ORG, or anywhere for that matter?
4. Can the grounds on the back of the heads be safely moved somewhere else? Furthest rear bolt on the intake? or ??. Is just a PITA to remove those grounds while the motor is in the car. TIA
