airborne_rex
Grand Nasty
- Feb 6, 2007
set of .040 cast pistons $150
stock cam $50
stock front cover $75
New HD actuator $60
headers $100
stock turbo $150
stock timing gear with chain $35
stock rocker arms $25
stock solid lifters and pushrods $75
stock valve covers $25
EGR and valve solenoid $80
set of 6 siemens 55lb injectors $200
stock intercooler $150
stock water pump $35
stock downpipe with crossover and test pipe $100
stock radiator $150
stock crank $80
Crank is .30 over and may need to be turned more, one of the pistons has a small nick on the top of it, no shaft play on the turbo unkown miles on it. Have gears for front cover if needed. Other than the actuator all parts are used and were working when taken off the car . If you want more details about any parts send pm. prices are negotiable.
stock cam $50
New HD actuator $60
headers $100
stock turbo $150
stock radiator $150
stock crank $80
