This is a second group of parts all of which are pictured below. All the parts were functioning when removed. I will try my best to respond in a timely manner. Please use the Direct Message feature to communicate with me. Please clearly identify yourself when you contact me. If you need a part overnight, that won't happen. I need time to search for the cheapest shipping cost and some of the parts will require that I actually make a shipping container. You can also contact me via email at deanpapageorge@gmail.com. I do have a Paypal account but simply sending me a check is perfectly fine. Thanks for looking. If the items don't sell they will be headed to the landfill unfortunately.
High mount brake light assembly (burgandy color) $10
Original rear differential cover and bolts $10
Evaporator heat shield $10
Speedometer cables - 2 sections $30
Supply and return fuel lines - engine side $30
Radiator support rods $5
Intercooler fan and bolts $20
Left and right side black door edge guards $10
Power steering reservoir and cap $20
Complete EGR assembly and hoses $20
Complete EGR assembly with hoses and wiring harness $35
Transmission/steering column interlock rods $15
Factory MAF $40
Fuel pump heat shield $5
Passenger side intercooler bracket $10
Driver side intercooler bracket $10
Steering pump hoses $20
Powermaster firewall bracket $5
Turbo oil return line $20
Chrome turbo shield $125
“Powerplate” intake spacer $10
Metal heater lines to intake $25
Trunk lid latch $5
Short transmission cooler lines at radiator side $10
Factory MAF $40
Trunk lid latch $5
