Gary Wells
White turbo Buick trailer park trash
- Mar 2, 2002
Handgun Shok-buff Recommendations: 09-29-2011
Ed Brown: Does not recommend the use of Shok-buffs in any of their guns and there is not enough room to accept a standard thick Shok-buff and sling-shot.
Les Baer: Shipped with a Shok-buff in at least their 5” Premier II guns but it is rumored that all or most will not sling-shot with the Shok-buff in place.
Wilson Combat: Shipped with a Wilson Combat Shok-buff in their 5” guns only.
A Shok-buff does limit the length that the slide travels backward.
Not all guns have enough room to use a Shok-buff and still slingshot.
Examples: Ed Browns, or at least the Executive Target & Les Baer, or at least the Premier II does not have enough room for a standard (.100-.105 thick) Shok-buff and still slingshot.
Guns that do not have enough room for a Shok-buff can exhibit 2 negative characteristics that could prove fatal in a life or death scenario.
1) Slide may not go back far enough to slingshot, that is allow the slide to be pulled back just enough to allow the slide to go forward to battery.
2) Shok-buff may limit rearward travel enough to not allow the slide to stay open on last round fired.
Other than those limitations, Shok-buffs are a matter of personal preference / option and have lots of haters.
If you are not familiar with a Shok-buff's limitations and use one, eventually it will screw you up, and not always at a convenient time.
Dawson Precision markets a .100 thick aluminum Shok-buff (# 032-001 DP 1911 HiCap Aluma Buff Shock Buffs) that is used by a lot of the gamers & competition shooters. Ones using it seem to be quite satisfied with it. These will not work in Les Baer or Ed Brown handguns without modification due to their thickness.
Joe Cominolli of Cominolli Custom makes a shock absorber type of device that requires 2 different thicknesses of Shok-buffs. He generally sells them as a combined set but if you call him he will sell you only the thin ones, which are black in color and measure about .062 thick.
I modified a standard .105 thick Shok-buff a while back by sanding it down to about .08 thick for my new Ed Brown Executive Target. Works like a charm.
I shoot 5 different 5" .45 autos, all wear 1 piece or 2 piece full-length guide rods, all are Shok-buffed, & all fully sling-shot.
I do not suggest that everybody else use either a FLGR or a Shok-buff as you are going to run into quite a few FLGR & Shok-buff haters.
I do not believe in cutting coils, removing material from the back of the slide dust cover, and I don't believe in not running a FLGR or a Shok-buff just because everybody else says not to run them.
