1987 Grand National
- Oct 12, 2012
My '87 GN with recently replaced cam(because it wiped the original) is bucking like an ignition problem and can't get out of it's own way. I have replaced the ICM and coil pack. No change. Also tested a known good pair from another car. New crank position sensor. TPS voltage looks good and smooth through out. MAF is at a 05 at idle. I have unplugged the MAF and Cam sensor while it was running with no real change. I don't feel the cam has been installed incorrectly. If it were I figured it would just be a turd and not have a surging problem. When I rev it in park it doesn't have a miss but it does seem to rev slower than before cam. Also the miss/surging problem did exist prior to doing the new cam. What do you guys think?
