I have a fresh engine that I am trying to get running right. The engine is mechanically sound. I took it to Fast Eddies in Tulsa, OK and he programed the F.A.S.T. computer. Everything is good except for now at high rpms 4800 and up it spits and misfires. Plugs (autolights)are gapped at .034, new wires, coil pack 1 year old. Tried messing with the timing and fuel but nothing made it better or worse. Now the last time a ran it, it spit a couple of times, turned the knock gauge on (which it would do everytime it spit) and then it died, now it will not start. I checked the fuel pressure and it is at 41lbs. I put a timing light on the #1 wire and when turning the engine over it just fires when it wants to. No rhythm at all, might fire, might not fire. I am thinking it is either the crank sensor or the cam sensor. Please help!!!!
