Missing....
Nocooler
Had a Hotair
Time for some opinions guys. The car stumbles on it self under load - but not WOT. The miss comes and goes. The only thing I have discovered is plug #6 is carboned. Is this a bad coil pak? Injector harness? Am I looking to deep? Bad ground? Plug wires are fine and everything else is normal, just a hard shudder under load - it has me thinking because it is intermitant not constant.
Jeremy
Are you getting any knock retard? I've always had part throttle knock on hot air cars for some reason. I feel that it is in the chip programming. JMHO.
Nope...got it fixed, just bad coil pak. I put the original 150,xxx mile one back on and it was fine (execpt it won't run when wet!).
Jeremy
