Has anyone used a combination of poly and rubber body mount in their street/strip GN, if so what was your results ? I am thinking about using poly upper and lower body mounts in position 1 & 7, then use rubber upper body mounts in position 2,3,4 & 6 with poly lowers and also use a rubber GNX mount in position 5. I am trying to duplicate the handling characteristics of the poly with out the annoying vibration that is associated with them. Do you think this approach will accomplish this ? Thanks, Kyle.
