mixing rubbing alcohol with meth
blueta
Well when I'm almost out of methanol I want to switch to rubbing alcohol since I have a really cheap/easy source for it. I was wondering if I could just add the iso. alky while I still have meth in the tank, or should I dump it first?
Sure. Mix em up. Only thing is consistency in the ratio of water to alcohol.
Trying to tune a car with alcohol and constantly changing things.. good luck. Your just getting yourself deeper into issues.
Stick to one fluid.. get that figured out.. then move on and start on something else.
Well I was doing a lot of searching last night and saw that you keep recommending 100% alcohol. So I decided to drain the rest of what I had and fill it with 100% isopropyl alcohol (yes it's actually 100% and not 70% mixture from a regular bottle ;) ), and just wait for my m10/15 jets to get here. I'm gonna stick with the rubbing since I can get it really cheap. Since this is what I'm gonna run I don't see how I'm gonna be getting in the "deeper in issues" since I was trying to tune with a WAY too small jet and I basically got to start over anyway. :confused: Thanks!
