H henschman Active Member Joined Jul 23, 2004 Oct 3, 2006 #1 the turbo i have (pt54) requires at least 55lb. injectors, according to several sites. will i need to mod the ecm to run that much injector, or just get a chip for them?
T Turbo231 Member Joined May 28, 2001 Oct 3, 2006 #2 I would run Motron 60lb high Z injectors and a good chip, no ECU mod needed.
pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Oct 3, 2006 #3 the 60/65 's are high Z and dont require ecm mod if you get 55s you will need to mod if it were me id go bigger than the min reccomended
