I am wanting to make my TTA faster for this next racing season. With the following mods my car has run 11.79 @ 114.7 with a 60' of 1.61.
7 position Caspers "Ultra Chip"
TA49 Turbo
36# injectors
Walbro 340 Fuel Pump
Action Fab 3” downpipe
freeflowing exhaust with testpipe
62mm throttle body
ported plenum
1" plenum spacer
adj fuel pressure regulator
ATR bleed valve to control boost
PTS 9/11 Torque Converter (Stalls at 3400)
LT1 MAF Sensor
Translator Plus
K&N 8" Air Filter on 3" Stainless Steel MAF pipe
110# valve springs
BFG Drag Radials on the stock rims
Spohn Adjustable Torque Arm
Global West Subframe Connectors
Spohn Adj Panhard Rod
Spohn Lower Control Arms
On the street I run 92 Chevron unleaded premium
At the strip I run Sunoco NOS Supreme Racing Fuel (117 octane)
At the strip my fuel pressure is set at 45#'s with the vaccum off and I run 21-23 #'s of boost. I have run with the #5 chip which gives me 22 degrees of advance at WOT and knock retard usually never exceeds 2-3 degrees.
I am considering going to a TA 60 turbo with MSD 50# fuel injectors and using the extender prom chip. I may also go to the Terry Houston downpipe later in the summer but the first three are what I am definitely considering. I am open for comments and/or suggestions.
TA49 Turbo
36# injectors
62mm throttle body
ported plenum
1" plenum spacer
LT1 MAF Sensor
Translator Plus
110# valve springs
