m233roller
Banned
- Jan 25, 2002
Here are some more parts off my 37,000 mile car and all parts are in excellent shape.
0 - 87 GN black grille with Buick badge on it. Nice grille. $225 SOLD !!
1 - Beautiful set of wheels, tires (originals with about 40% rubber on them and NO weather checking or rot ) center caps and lug nuts. $1000
2 - Both intercooler brackets. $25 each
3 - Original turbo & intercooler hoses with clamps. $25 SOLD !!
4 - Intercooler fan (NICE) $35 SOLD !!
5 - Wastegate Y hose, still has the GM sticker on it. $45 SOLD
6 - Console ash tray, never smoked in but has a couple of spots down in it. $45
7 - Cigarette lighter and dash socket, Like New. $45
8 - Black seat belt holders, mount on headrest.Perfect. $25
9 - Turbo J bracket. Like new. $45 SOLD !!
10 - Ignition module flat mounting plate. $25 SOLD !!
11 - Both alt. brackets. $25 each SOLD !!
12 - Throttle cable bracket. $25 SOLD !!
13 - Turbo cover, looks like most of them (kind of shitty) $35
14 - Return fuel line in nice shape (NOT rusty) $25
15 - Turbo oil drain back tube. $30
16 - Trans. dip stick and tube. (NICE) $50
17 - Oil dip stick that is mint. $35 SOLD !!
18 - Water pump pulley (NICE) $25
19 - Lower crank hub & pulley (NICE) $45
20 - Nice motor mounts, left side is like new GM. $50 for the pair.
21 - Stock, NICE up pipe. $25 SOLD !!
22 - All 4 sensors on the passenger side with the mounting bracket.
Very nice. $50 SOLD !!
23 - Sensor bunch. Tps, Iac, crank sensor with bracket and all 3 temp sensors. $100 for all 6. SOLD !!
24 - Delay relay sensor. $50
25 - Known good ignition module. $50 SOLD !!
26 - Set of stock rockers and push rods, 37,000 miles on them. They look new. $50
27 - Gray pull straps, like new. $35 for the pair.
28 - Right side black marker light (like New) $35
29 - Cat. Conv. $150
30 - Complete tie rod and center drag link off my show car. $50 SOLD !!
31 - All 4 wheel well moldings in very nice shape a couple of small paint chips on two of them but Not dented up. $125 for all 4. SOLD !!
32 - Stock driveshaft. $75
33 - Both front coil springs. Nice. $45
34 - Nice lower intake manifold. $250
Some more nice clean parts.
A - Throttle body with linkage off my 37,000 mile engine. $75
B - Complete set of astro roof drive cables. $150
C - Astro roof motor and switch. $50
D - Known good LS-1 maf sensor. $50
E - Nice gray horn center with aftermarket GN button on it. $35
F - Pair of nice black park light bezels. $50
G - A/C compressor. $75 SOLD !!
H - Nice GM timing cover, Nice gear pocket. $75
I - Set of Kenny Bell roller rockers (Red, so I think they are 1;60 ratio)
Some of the rollers are rough. $100 for the set. SOLD !!
J - Rear hood molding $50
K - Beautiful GN hood. $450 LOCAL ONLY !!
L - Stay down license plate holder. Sandblasted and painted gloss black. $25
M - Both outside mirrors off my show car. Right one is a fixed style.
You can just bolt these on as paint is perfect. $150 for the pair
N - Left or right side black door hinges. These were new GM 3 years ago when I painted the car. Perfect shape $75 a side.
O - Nice tilt stalks. $15 each
P - Pair of nice door jamb vents. $25
Q - Correct for our cars very nice inside rear view mirrors. $20each
U - New aldl covers. $10 each
V - Caspers field fix. NEW $25 SOLD !!
ALL PARTS ARE PLUS SHIPPING AND PAYPAL FEES
Can get you pics. of any part. Thanks Mike
