No I set it at 45 line on. Still runs lean up top(according to the o2 voltage 500's) when I set it to 45 static and runs very rich at idle or tip in(according to blms 90-98 but o2 voltage is around 740 -780mv). The only thing that is left is the chip. Only way to see everything going on is direct scan which I don't have. Maybe for christmas I'll treat myself.
However I am finally figuring out the extender a little. It lets you adjust the fuel in the blm cell during spool up, can lock lean cruise in od and either lock it in open loop or closed loop.. Now no more gradual boost and can build 4-5 psi while brake spooling. It has enough fuel pressure up top just not getting the o2's where it should be. It's hard to tell cause the chip locks the INT and BLM @ 128 more than 1/2 throttle. I will try the thrasher chip and see what she does then.
