Jay, Dan, anyone?
I have my Propain kit in hand (well, most of it) and was able to bench test the command center last night - works perfect!
I was wanting to know what size wire/fuse is needed as the solenoid is pretty massive. I have an available 16GA wire with 10A fuse, but if not enough, will run heavier.
For concerns, what happens if the solenoid leaks through and fills the intake tract with propane, then an unsuspecting driver tries to start the car? Theoretically, if leaky, the propane could back out through the intake/air filter and travel through the engine/exhaust system and on into the garage! Is there any documentation on "tightness" of the solenoid valves? I'd like to NOT have to turn the bottle on/off every time I drive it...
TIA!
TIA!
