Okay,
Thanks for all the help so far. This is a 2-part question continuing from my first post...
Help with a “STALE 87 GN” http://www.turbobuick.com/forums/showthread.php?s=&threadid=147131
Okay, I'm making progress. Drained the gas, changed the fluids, replaced the battery. No problem, I now have the car running. Starts fine, idles fine, sounds fine. I have not changed the plugs yet. I’ll do that is the next day or so.
One point I want everyone to know. This GN is not even close to being stock. It has had a lot of upgrades over the years. It is a high 10-second car. I have a PILE of receipts that may shed light on all that has been done to it.
1st question,
After it sits and idles for about 1 or 2 minutes it starts smoking heavily. I took it out for a 2-mile drive and it smoked immediately at all stop signs. I assume it smokes while I’m driving. I can’t tell while I’m moving. It is a blue/white smoke so I'm assuming it is fuel. It causes the typical watery burning eyes. It will drive you out of a two-car garage in less than 1 minute. The exhaust tips are also very wet.
I was told it did smoke “a little” when it was parked 3 or 4 years ago. Who knows what they mean by “a little”. I say it smokes A WHOLE LOT now.
So… any idea to what this smoking problem is or how to figure it out???
2nd question
During the 2-mile drive I went on I got the turbo to “spool up” a few times. Builds boost, sounds good, no problem. I did not push it hard at all!!!
This may be normal, I don’t know. Each time I get off the gas to stop boost the turbo makes more noise when it shuts down than I would think it would. It’s not a “bad noise” it’s a whirling wind type noise. No metal sounds or screeching of any kind. It’s just louder than I would expect it to be.
So… is this turbo sound normal or do I have a problem here???
Once again thanks for all your help.
1st question,
2nd question
