tonylukejr
- Aug 31, 2002
I have a 1987 GN. The person I bought it from said it was doing high to mid 12's. I would like to be doing low 11's with pump gas. Here is a list of what I have in it. Any sugestions on what I should change or add to help get the car in the 11's would be appreciated.
ENGINE was completely rebuilt Bottom half of ENGINE completely balanced
NEW PISTONS and RINGS
NEW CAM
NEW KNOCK and CRANK SENSORS
NEW BEARINGS
NEW FREEZE PLUGS and SEALS.
STOCK INTAKE
STOCK THROTLE BODY
STOCK HEADS
STOCK REAR AXLE 3.42 GEARS
STOCK INTERCOOLER
ADJUSTIBLE FUEL PRESSURE REGULATOR
High Performance CAM SHAFT
High Performance LIFTERS
High Performance PUSHRODS
High Performance VALVE SPRINGS,
High Performance DOUBLE ROLLER TIMING CHAIN SET
High Performance HIGH VOLUME OIL PUMP
High Performance TIMING COVER
40-PSI INJECTORS
TE44C- TURBO with adjustable WASTEGATE
WALBRO 340 INTANK FUEL PUMP
3 INCH DOWN PIPE
HIGH FLOW CAT CONVERTER
3-INCH EXHAUST SYSTEM FRONT TO BACK WITH OPEN CUT OUT
2 FLOW MASTER TWO CHAMBER MUFFLERS
TRANSMISSION done by ART CARR trans has all EXTREME DUTY PARTS and can handle 850 hp.
CONVERTER IS 9 INCH 3600 STALL.
The CHIP IS THE ULTRA CHIP.
HYPERTECH 160-DEGREE STAT.
Well thats everything
NEW CAM
NEW BEARINGS
STOCK INTAKE
STOCK THROTLE BODY
STOCK HEADS
STOCK INTERCOOLER
40-PSI INJECTORS
3 INCH DOWN PIPE
