I recently installed a roller camshaft with morel (pbm) hydraulic roller lifters. In the past when using flat tappets I have found it relatively easy to press the plunger down before they have been installed and had oil pressure.
I used a checker pushrod and got the correct length for .030" lifter preload and ordered the pushrods. When they arrived, I dropped them into place and noticed that I couldn't push the plunger in the lifter down by hand at all. I figured that this must be normal
I bolted the rocker arms on and could tell the pushrod side of the rocker arm moved down a shade after getting to zero lash.
I haven't driven the car very much so far after finishing the install, but everything seems to be running fine. I was just wondering if everyone saw the same thing that has installed a set.
