moroso trick front springs
jbaker
anyone using moroso trick front springs? if so what is your frontend weight and what part number did you install. was ther any trimming reqd? thanks
Nick,
you had to trim them? I put them on my car and the front end went way down, too low even for me. That was with a stock suspension car and front glass bumper.This was with the heavier set #47135
I have taken about 80lbs off the nose and im gonna retry them.
coils
My son has a new set, had to use 3/4 in. spacers. I got a used set from a friend, installed them and the front end went to the ground. I tried spacer but never could get the inner fender off the tires. Gave up on them!! Rumor has it that Morrroso only pays about $8 per spring for these. Quality control not very high on their list!!
