Nov 8, 2005 #1 C ChrisChow Member Joined May 28, 2001 Messages 452 Posting for a friend. No dissappointments. This M600 is loaded. Has all the options purchased. Call 702 400 8157.
Nov 8, 2005 #2 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,212 where can i read up more on the m600 ?
Nov 8, 2005 #3 S straycat990 Senior Member Joined Mar 11, 2002 Messages 233 norbs said: where can i read up more on the m600 ? Click to expand... http://www.motec.com/products/ecu/control.htm#M600 Chris any idea what your friend is asking for it?
Nov 8, 2005 #4 C CTX-SLPR Active Member Joined Feb 4, 2004 Messages 1,942 This thing capable of running a MAF? (yes I like Mass Air Flow systems!)
Nov 8, 2005 #5 T turbo261977 New Member Joined Jul 3, 2005 Messages 33 hey chris loved you dyno pull that is all over the net thanks again
Nov 9, 2005 #6 T turbo261977 New Member Joined Jul 3, 2005 Messages 33 And Lets Not Forget Getting In The 7s Great Work Out There Hope To See Some Clips On Here Soon Thanks Again
Nov 10, 2005 #7 C ChrisChow Member Joined May 28, 2001 Messages 452 straycat990 said: http://www.motec.com/products/ecu/control.htm#M600 Chris any idea what your friend is asking for it? Click to expand... I think around 4K negotiable. Retail is almost double.
Nov 10, 2005 #8 C ChrisChow Member Joined May 28, 2001 Messages 452 turbo261977 said: Getting In The 7s Great Work Out There Hope To See Some Clips On Here Soon Thanks Again Click to expand... Videos are UP. Check the fasttrackperformance.com website.
Nov 12, 2005 #9 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,212 Does this unit come with a harness or is it plug in play? Will the factory crank sensor/trigger wheel work?
Nov 13, 2005 #10 C ChrisChow Member Joined May 28, 2001 Messages 452 norbs said: Does this unit come with a harness or is it plug in play? Will the factory crank sensor/trigger wheel work? Click to expand... No harness. You have to make your own.
Nov 14, 2005 #11 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,212 will the factory crank trigger work? Do you have connectors for the ecu?
