SignUp Now!get it to work? are you using m48?
we have not been using the rise rate untill now. it is not needed to run the 2 step. motec has an ignition box or we used MSD al-7 both need a distributor. which will make more powerI figured out how to install the 2-step. I ended up using one of the digital inputs. I just need to figure out the rise rate. I am not sure how many rpms per second to set the rise to. The overrun boost is another nice feature. I used it for a quick spool up while on the brake. I am still learning. The car sounds like a evil machine gun on the transbrake with extra fuel and firing of cylinders every other stroke.
when were not running in PSCA, i use nitrous to spool. (i have a loose converter for to run in PSCA 10.5 outlaw) kenny told me you cant use the boost builder with an auto trans. i dont know much about the over run boost. did you try it with the converter loaded on the transbrake?Len,
What functions do you use for quick spool-up?
