How you mounted it right in front of the condenser is how I had mine along with an oil cooler....................I had trouble every summer running a CAS V2 a CAS gigantic aluminum radiator and a CAS high volume water pump. The A/C didn't work worth a damn, when, well you know, when it was blazing hot in traffic and I needed it the most. The temp gauge would steadily rise when I ran the A/C and was not moving at cruise speed.
Then I swapped the FMIC for a Precision SLIC and now all is perfect, no more issues and the A/C is bloody well cold as ice all day long and the trans and oil cooler sit prominately right in front of the condense grabbing all the air. The car is way more drivable and screams just as well as it did with the front mount.
Mike
