Mounting the Precision FMIC - old style
Black Power
I bought a used Precision Turbo FMIC from a guy on here, it's the one that has the studs pointing up, it doesn't bolt to where the x-brace was.
How do I mount this thing???
I mounted mine by locating the stud spacing on the top of the core support. I then drilled a 1/8" guide hole thru, then used a Unibit to drill a hole for the studs..[5/16"??]
I then enlarged the top holes so I could drop washers and a nut down on the stud. Done deal....
Worked for me.
Worked for me.
Sounds like a plan, thank you sir :cool:
