mph for te44
boost ? timing? I'll assume on 100 u can run 20 * timing and 20#s of boost, this should net around 112-115 depending on tire size and whether you are locking the TC or not. With the GN1s you may mph a little higher. With 19* timing and 23 psi on 110/93 mix i went 115.4, and on 112 and 23* and 23 psi i went 118.
I've got a alky chip in now. I think it's 23 * timing an drops to 21*. Boost was 17lbs when I went 111mph Saturday. Track was to crowded (only ran twice) and I striped a lug nut, so I couldn't put my slicks on or I would have tried to turn the boost up more as I wasn't getting any knock and the O2's were on the rich side. Tires I was running was 235s 60 bfgs.
Should I lower the timing to 20 and run higher boost? Was running 17lbs and 23/21 degree alky chip with no knock.
