OK, install is done with FAST using OEM TFI ignition - no fire, no rpm reading on FAST dashboard, no Tach reading inside either.
BUT, this likely has to do with the voodoo wiring Saleen did when they recalled/rewired a bunch of cars to EEC-V 104 pin processors(vice 60 pin).
So Im looking for information on a MSD Crank trigger system in the hope that this can be plug & play despite the unknown factory ignition harness. The FAST directions dont answer much. Do I need a different distributor for this? What about new harmonic balancer?
Any guidance or direction on "starting from scratch" on a 351 Windsor to use a Crank trigger system would be greatly appreciated.
Kirk
Kirk
