I located two cars here in town to test the MSD DIS-4 unit on. One car was a Buick T-Type that I found out already had a DIS-4 installed on it over two years ago without any problems. The second car was a 1996 Buick GN which we got in here on Wednesday and did the install. One of our Engineers tested the stock ignition system on the car with an oscilloscope before we started the install. We installed a newer DIS-4 unit, PN 6215, an Interface Module, PN 8878, and a set of MSD Super Conductor Spark Plug Wires, PN 31869. The Engineer again probed the car to check the trigger signals. We then installed a much older DIS-4 unit and he probed the car again to check the trigger signals. The car has several performance mods done to it including a cam, alcohol injection, Corvette MAF, 12psi boost, etc. and ran flawless with the DIS-4 installed on the stock ignition system. We also have another Buick GN in town that we did an install on in 1999 with a stock ignition system that has not had any problems. We know we have a compatibility problem with the FAST system and have forwarded all of our oscilloscope graphs to them. Another manager here is in touch with them and FAST is now scheduling a meeting to discuss our findings.
Spike Clapper
Customer Service Manager
MSD Ignition
