1986 Buick GX1
GX1 #001 [The One and Only]
- Apr 24, 2015
I've visited from time to time over the last 10 yrs. now it's time to be active.
This is my 1986 Buick GN, bought new from Richard motors LTD in Charles city Iowa. I ordered the car May 10 and picked it up two months later (July 10) with less than 3 mi on the odometer and have enjoyed driving every one of the 71k mi that are on the car now.
I ordered it as a bare bones car with minimal options, halogen headlamps, carpet mats, digital dash, best radio and posi (posi was not standard equipment in '86). No power windows, no power door locks, no power seats, no power antenna. No heavy t-tops or sun roof.
The car weighs 3300lbs (3450 with me in it) at the elevator scale.
The GX1 is my thing, just something different.
A few mods:
TA49 turbo
80lb fuel injectors w/ TT 5.7-E85
Amped up DW300 fuel pump
Volt boosted
Hallman Pro boost controller
PTE plenum and RJC power plate
Mease 15 row stock location intercooler w/ TR Customs I/C tag
Custom 3.5 MAF pipe
Z06 85mm maf & X-lator
Kenne-Bell intake kool valves
DUI 10mm livewires
Dual 14in. slim line fans w/ custom shroud (3100 CFM)
Kenne-Bell ram air/ intercooler scoop
CPP under drive crank pulley
Custom alternator pulley w/ billet fan
GNX body brace
RJC motor brace
Husek 3021HF converter .085 EP
Art Carr shift kit w/ super extreme trans cooler
Ported factory headers
TA performance 3.5 down pipe
Connleys performance plus Mag tune 3in dual exhaust
Vacuum brake conversion w/ '86 Monte SS M/C, booster and pedal
SSBC rear disk brake kit
Kenne-Bell lift bars (lowers) - UMI Uppers
UMI performance 1" lowering springs
Bilstein shocks
Herb Adams/ Moroso swaybars
Front: 1 5/16" w/ heim joint end links, ADDCO urethane bushings
Rear: 1 1/2" (lower control arm mounted)
HRE 504 wheels
Front: 17x8.5 w/ 255/40-17 Dunlop SP8000
Rear: 17x9. w/ 285/40-17 Dunlop SP8000
ATR diff girdle
Kirbans Grand National horn medallion
BGC seatbelt guides
199 mph digital dash upgrade w/ built in detonation detector & tinted lens
Custom SS ashtray 6 switch panel with brake light cutout, fog light, high/ low/ delay off fan control and fuel pump shut off switches +2 X-tra
Hella vision + H4/ H1 conversion w/ LED
Factory look driving lights w/ H3 LED
A few mods:
TA49 turbo
Volt boosted
Custom 3.5 MAF pipe
DUI 10mm livewires
GNX body brace
RJC motor brace
Bilstein shocks
HRE 504 wheels
ATR diff girdle
BGC seatbelt guides
