my 3" dP for those who care
suggestions..
ATR up pipe if possible, and wrap it in header wrap, the whole thing.
wrap the top half of the downpipe as well.
maybe look in to re-wiring your coil pack, its an 86/87 coil and module and the wiring looks horrible.. will cause you problems down the road.
and see if you can find some high quality thick rubber caps to put over the coolant nipples instead of a looped piece of hose..
capped the coolant lines w/ some vac caps yest;)
plan on redoing the wiring too...looks like **** but at least he soldered them...
Looks like the same DP that I have. Got mine from Eastern Performance around 4 years ago. Its a 2 piece 3". Dan Smith had told me that it was actually made by Accu-fab.
I had forgotten about that weld in the middle of the top section. I had grinded it down smooth then repainted it. Looks much better this way ;) . Then again, I put header wrap on the top section last year so you cant see it anyway :rolleyes: .
watch out with those vac caps.. i dont know if it was jsut me but they could spout pinhole leaks and make your engine compartment a mess... mine have done it 2 times. clamp them TIGHT!
